Делитесь своим опытом!
Решено! Перейти к решению.
You might be dealing with a faulty screen. I recommend you contact your local support team with the link in my signature to arrange a repair.
I doubt that its related to the latest update, check this
settings > about phone > diagnostics > test > test touchscreen
Hi @Haystax,
Welcome to the community.
It does seem odd that it would happen right after the update. It's possible the update didn't install correctly. I recommend running a software repair.
No cracks on screen....Not even hairline ones..
Hi there!I have the same problem now with my z3 compact.. at first the notification drop down was no longer responding..and now the back button also not responding. I thinkthe problem is in between the interaction software to hardware. Since this only happens after I updated to Lollipop. Sony Mobile should do some pactch or global update for this.
