Z5 compact not 100% charged
SOLVED
ab3605
Visitor
Charged the phone last night, though the screen says 3 more minute until fully charge, but, 45 minute later, it still stays at 98%. Any solution to this issue?
1 ACCEPTED SOLUTION
Accepted Solutions
CameronT
Champion
Hi @ab3605,
Welcome to the community.
Try shutting the phone down, then connecting it to the charger, charging it to full, then power it back on.
4 REPLIES 4
CameronT
Champion
Hi @ab3605,
ab3605
Visitor
OK, will try tonite and report back to you asap.
ab3605
Visitor
Happy to report that it does now charging to 100% with the phone shutting down but not happy that I have to shutting down the phone only to have it 100% charged which my previous cheap phone able to do without shutting it down.
CameronT
Champion
The battery would have been full, it was just displaying the incorrect amount. I'm glad it's sorted for you Slightly_smiling_Face
