Z5 Display issue
SOLVED
AndrewKay
Visitor
Z5 Display issue
Sorry for my english...
The screen has an area of brighter backlight in its center. Looks like a brighter horizontal line, especially on white backgrounds. So the most material apps are very uncomfortable to use!
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.US.title
Qatrium
@AndrewKay
Don't expect the worse, it's a new phone and if you didn't drop or damage it then it might be a manufacturing defect. I assume also that you have warranty, so just go and get it examined by authorized professional.
3 REPLIES 3
Qatrium
@AndrewKay
I'd try first to boot in safe mode and check if it occurs there, just to make sure it's not a software issue. But most probably it's hardware, and I strongly suggest that you contact your Local support to get it examined.
AndrewKay
Visitor
It's 100% hardware. I'm just affraid, Sony will not repair it, as it was with Z2 Tablet.
Qatrium
@AndrewKay
