Sony A900 problem
SOLVED
mantelbb
Explorer
Sony A900 problem
Steady shot scale indicator is always on low? Function of Steay Shot is OK
That is only problem on camera i Want to buy, can you help me with some coments?
1 ACCEPTED SOLUTION
Accepted Solutions
Bieomax
Member
It might be something or nothing, I'd personally be a little wiry if there seems to be a problem with the sss as it may indicate it's been bumped or dropped. But I would also look on the Sony Support site and have a read of the manual just incase it's something normal or a setting that's been switched on/off
There is also the price to take into consideration, if its a very good deal it maybe worth the punt.
2 REPLIES 2
Bieomax
Member
mantelbb
Explorer
Thanks,
I am still hesitant to purchase
