Regarding the above TV which I recently bought, I'm assuming that this model has no Bluetooth functionality? I can't find any reference to it within the manual. I'm looking to listen to the TV via my Bluetooth headphones.
Solved! Go to Solution.
Hi,
That's correct - this TV is not equipped with BT functionality.
You would need a BT transmitter that can be connected to the headphones output of the TV.
Cheers
