My tv seems to be stuck on the loading screen, I've tried plugging the tv in with the volume- and standby buttons pressed then I get a green led but it just turns off after that
Any help would be appreciated
Thanks Iain
Hi,
Please disable your network/router and try again afterwards.
If it still fails please get in touch with Sony customer support.
Cheers
Thanks but turning the internet off didn't work so I have contacted support and someone is coming to look at ther tv
Do let us know what the response is as it would help others with the same issue ^^
The tv engineer has told me he needs to replace the main board in the tv, hes got it on order and said he'll arrange a visit to replace it
I'll let you know how he gets on when hes been
