ax53 help with memory card
SOLVED
motorhomer
Member
Hello all
I have just bought the AX53 camcorder and wanted to get the bet SD card for recording in 4k
I already have a Sandisk Extreme 90mb/s 64GB card which is ok in all formats except 4K
So I was told to get an extreme pro card. I bought the following
SanDisk Extreme PRO 128GB Class 10 SDXC Memory Card 4K Ultra HD
but I get the following error when I turn on the camera
Either switch to sdxc class 10 or uhs-ii compatible memory card or change file format
I assume from this that the card I bought is not compatible with this camcorder
Can someone please recommend the best one to get so I don't waist anymore money
17 REPLIES 17
IamNic
Hello @motorhomer,
@motorhomer  schrieb:
IamNic if you have the same card
I actually have five or six of these cards, so yes, they definetly work.
Are you certain the card is genuine? There are many counterfeit cards around nowadays which are slower/smaller cards with a fake sticker and config file.
- Nic
motorhomer
Member
not sure how to see if it is genuine. Bought from an ebay supplier with 100% positive feedback and 25 sold with no problems most people found it run faster in devices.
It works ok on my Canon DSLR and in the laptop
also came in an original packaging.
I would say from what I can see this is genuine but how can you really tell
IamNic
Hello @motorhomer,
here is how you find out whether the card is fake or not: https://photographylife.com/fake-memory-cards
- Nic
motorhomer
Member
Thanks for the link, I think you may be write. No serial number on the back which all scandisk have.
write speed 10 mb/s
read speed 13mb/s
which is slow compared to my 90mb/s card which reached over 24 mb/s on both read and write.
I will contact ebay to report this and request a refund
motorhomer
Member
Nic thank you for your help with this, least this is one problem solved.
Camcorder still going back as not happy with the volume problem. If I get a refund will be looking at possible a canon camcorder if i can get one under £500 with external mic jack and stabilization.
IamNic
Hello @motorhomer,
can you link to the post here in the community, where you describe said problem?
Maybe it is just a settings issue!?
A V30 card should allow 30MB/s writespeed (or very close to that, depending on how you have the card hooked up to the PC you are testing the writespeed with.
- Nic
motorhomer
Member
Having trouble posting the link so hopefully this one works.
The conversation on the audio is in this link
I uploaded some videos to my youtube with the issues under my channel link
motorhomer
Member
Dont think the link is working again, if you look under cameras > camcorders my discussion is titled near the top
AX54 audio stereo levels not constant balance
or its under my user name
