the auto rotate of my xperia s is not functioning at home screen and application screen. it functions only while charging. please help me..
Solved! Go to Solution.
auto rotate normally doesn't work on home screen and app screen, it only rotates when you connect it to the dock accessory,
I think a software repair using Sony update service would help
now even while charging, auto rotate didnt works:(
Correct what nolramlb states above, it could very though in between different softwares. But in general the homescreen won't rotate.
