My phone displays both number keyboard and contacts behind it. Here is screenshot:
Any way to fix it?
model: ST21i
build : 11.0.A.0.16
Solved! Go to Solution.
I have never seen this before. I suggest that you try to reboot the phone and check if it remains. If yes try to reinstall the phone software using SUS. That should fix the problem.
Installd fresh update and that solved my issue
