I am planning to buy a headset for my Tipo Dual.
Choices are
1. MW600
2. Livesound Hi-fi headset
3. MH650.
Can someone guide me which are the compatible with Sony Xperia Tipo Dual & which one will be best in terms of sound quality?
Also what is the full model no of the Livesound Hi-fi Headset?
Differences between MH1B, MH1C, MH1WO...
Solved! Go to Solution.
The Xperia tipo dual uses a sound standard that is called CTIA and there for you also need a headset that uses the same one. The headset I'd recommend you to take a look at is Smart Headset, since both MH650 & Livesound uses another one called OMTP.
You can find more info about the Smart Headset on the link below.
http://www.sonymobile.com/gb/support/accessories/smart-headset/
The Livesound headset is named MH1.
Thank you Petter for the info. Can you please clarify whether MW 600 uses CTIA or not. I have checked the user manual but couldn't found that info.
Thanks in advance..
