external SD (ext_card) and internal storage are not detected in windows after upgrading to ICS
SOLVED
totoymola
Visitor
Before I upgraded to ICs, Windows can detect both  my built-in and my external SD card
It used to show on My Computer as two separate storage drives.
Only yesterday, after I upgraded to ICS, Windows cannot detect any of the storages.
But my phone notification says "Int. storage and SD card connected to PC"
I also tried erasing my external card but still not luck.
What should I do?
Any help are greatly appreciated.
Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
anand_raj
Visitor
Try this. Go to settings - Xperia - Connectivity - check the square next to Install PC Companion. Then try connecting via USB. This should work.
2 REPLIES 2
anand_raj
Visitor
totoymola
Visitor
thanks anand_rj.. you saved my day!:smileycool:
