hi all
SOLVED
julio
Visitor
hi all
help me . i have a problem with my xperia x10 mini  , when i open data traffic and go to broswer it turnet off  , i turn on again close the data traffic and not turnet off but when i try to make a photo it turnet off again so when i put in charging it not doing this prob . help me plzzz
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
29 REPLIES 29
Uliwooly
Check this
  1. if you have a data plan
  2. if you have the correct apn settings
  3. if your SIM card its older than 1 year you should get a new one
  4. if you have antivirus and / or taskillers you should uninstall them
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
julio
Visitor
thank u but for that say me there are correct my sim card in older than 1 year but when i changet sim card again doing that problem . when it turnet off just turnet off not say that is turning off , i try to reinstall sony pc companion i installet again in my phone i make upgrade and again this problem .SORRY ABOUT MY ENGLISH . I dont know what have . and when i put in charging it was 50 % bateryy anf for 1 secont it going 100% soo ?? where is the problem??
Uliwooly
so the issue is that the data traffic doesn't turn off? how do you turn it on/off?
julio
Visitor
in charching
Uliwooly
could you elaborate?
julio
Visitor
yes when it is in charging
Uliwooly
julio
Visitor
ok i say u something else ,when im not at my home it not doing that problem but when i coming back in my home it turnet off , why only in my home ???
Uliwooly
so the problem is that your data plan doesn't turn on at your house? if that so then you don't have coverage at your house
