Hi all,
I got the new Anfdroid Gingerbread upgrade last night, but have only just found out that the the back up I ran using the the SE app will not be accessible after running the upgrade!!
Can anyone please let me know if any of the apps on android market can pick up my backup and restore it to my X10, as I've basically now got a phone with no contacts, apps, messages or any data what so ever on it!!! HEEEEELLLLPPP!!!
Cheers
Odub
Solved! Go to Solution.
many thanks ! this changed my day
seriously, I'm not making upgrade without reading the docs. I find that the fact that backup and restore doesn't work anymore should be highlighted a little bit more...
anyway, thanks again !
already downloaded the files in megaupload but there's no apk files..only have androidmanifest.xml,classes.dex,license,notice and resource.arsc...help me please..
anytime
thanks a lot...i did successfully restore....:smileygrin:
Glad to hear it worked out
ok you will have to do the following
1) uninstall and reinstall the backup & restore app
2) try to see if you can restore all your contacts
now regarding multiple repeated contacts
Thanks for that small guide. It *nearly* saved my a**... I was able to restore everything, except my text messages.
The restore procedure just stops at 3% and reports an error "Could not restore data" (I have 2 different backups from last week and both show the same behaviour). I cannot believe that both .sbf backup files are corrupted at the same place, so I wonder if you (or anyone for that matter) has another way for me to restore my text messages from this .sbf backup file (or convert it into another format that can be restored with another app maybe)?
So far I have tried a dozen different free restore apps from the market, but none of the could read the file / restore it.
Any help is greatly appreciated.
uninstall the backup & restore app -> reinstall it
and when you run it, only restore the SMS nothing else (not even MMS)
