Lost Backup with Android Gingerbread upgrade
SOLVED
Not applicable
Hi all,
I got the new Anfdroid Gingerbread upgrade last night, but have only just found out that the the back up I ran using the the SE app will not be accessible after running the upgrade!!
Can anyone please let me know if any of the apps on android market can pick up my backup and restore it to my X10, as I've basically now got a phone with no contacts, apps, messages or any data what so ever on it!!! HEEEEELLLLPPP!!!
Cheers
Odub
206 REPLIES 206
Uliwooly
once you restore them, check this other apps to backup sms/mms
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Not applicable
Thanks for the quick reply.
I tried as you suggested, but the problem remains: Error at 3% (on both backup versions) when restoring only text messages.
Any ideas?
PS: Way ahead of you on the 3rd party backup software. I'm never running any SE exclusive app again.
Not applicable
Hey,
Thanks for your tips. I had the same issue with backup and restore not being installed using the SE way but downloading the apk manually worked a charm!!! Thanks a ton
Uliwooly
no problem
Not applicable
Hi Uliwooly, my issue is can't download the Backup & restore V010935.apk from megaupload. Would there be any other website or link I can get this file. Hope you can help me, a million thanks!!
Uliwooly
how about this
Not applicable
many thanks for your quick reply, I got the file, follow your instruction and put it into the X10. Much regret I try to install it but it can't complete(Showing ~ Application not installed). Do you know why this happen? Exhausted!!
Is the file i download from that link is differ from the one in Mageupload? Hopefully can fix it today, couldn't sleep:(
Uliwooly
that happened to me before when I installed it on the Arc, what I did was to downloaded it directly from my phone and it worked just fine
Not applicable
Would you explain the process? Billion thanks!!!!
Uliwooly
on you X10 go to this site
http://www.megaupload.com/?d=I5CJUPJV
and download the file
use OI File Manager on your X10 -> click on Download -> tap on backup & restore -> install it
