Lost Backup with Android Gingerbread upgrade
SOLVED
Not applicable
Hi all,
I got the new Anfdroid Gingerbread upgrade last night, but have only just found out that the the back up I ran using the the SE app will not be accessible after running the upgrade!!
Can anyone please let me know if any of the apps on android market can pick up my backup and restore it to my X10, as I've basically now got a phone with no contacts, apps, messages or any data what so ever on it!!! HEEEEELLLLPPP!!!
Cheers
Odub
206 REPLIES 206
Uliwooly
anytime Slightly_smiling_Face
Not applicable
please help me~~i'm one of owner x10i and when i update my phone i lost all my data,i acknowledge that SE backup and restore didnt work for v2.3,i already do backup before i update but now everything lost,do you know any application can read backup file as SE backup and restore application because i try to install many backup application but cant detect the backup file that i made before with SE backup and restore~~please~~i need all my data urgently,tq
Uliwooly
Not applicable
Hi wolly,I've tried downloading the back up and restore from m.sonyericsson.com/backup but it keeps saying application not installed 😞
Uliwooly
that's why you should use this method instead
to download the apk
http://www.megaupload.com/?d=I5CJUPJV
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Not applicable
Shall try it now thanks !
Uliwooly
let me know if you need anymore help
http://talk.sonyericsson.com/thread/20218
Not applicable
Okay so i've installed to OI file manager.
For the instruction : download the backup & restore app, transfer it to your SD card, use  OI file manager to find it -> tap on it -> install it
where do I download the backup and restore app?
thanks !
Uliwooly
from this link
download the apk
Not applicable
Okay done,so i just paste it in my phone's folder? :smileygrin:
