Hi,
on my phone NFC has never been working. Neither on GB nor on ICS. I tried it with those red an black tags on the SmartTagApp and also with the NFC TagInfo (https://play.google.com/store/apps/details?id=at.mroland.android.apps.nfctaginfo&feature=search_resu...). But nothing happens. I'm not sure if it is the phone or the tags.
NFC can be activated and the symbol is shown on the topline.
Greeting windhund
Solved! Go to Solution.
After you start NFC,you should just take the tags where the camera phone is(a little lower) and you should get a message on the phone.
To be able to exclude what part may be causing this problem it's wise to try with another unit using NFC, such as another phone for example.
Try it out and see wether it works out or not. And of course, you need to make sure you touch the right part of the phone.
What do you think about this forum? Let us know by doing this short survey.
I think I tried my phones whole backside... Stills not working.
Yes, my problem is that I don't have another phone to try those tags or other tags to exclude that they are broken.
