sensor touchscreen is not responding!!!!!
SOLVED
evgenydoc
Visitor
Good day!!! Help please! Ihave my Ray for 2 years! Recently I came home and recognized that sensor wasn't operating! I've tried to extract battery and put it back then restart the phone but nothing happened (I mean phone is on but sensor touchscreen wasn't working). I've made this procedure lot of times but in vain. Tell me what to do please. Conditions of phone usage: -13 outside aprox 70 humidity!
1 ACCEPTED SOLUTION
Accepted Solutions
Sam
Legend
Legend
Please try running an update/repair as a first step to potentially resolving this:
1. Before you start you have to download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Note! For some models you will be prompted to do a backup prior to the update and then restore.
3. Install and open PC Companion then select Support Zone.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
What are your thoughts about this forum? Let us know by doing this short survey.
2 REPLIES 2
Sam
Legend
Legend
5. Start.
6. Repair Phone
7. Continue
9. Next
11. Select Phone
evgenydoc
Visitor
Thank you! Will try this method!!
