hellow
my xperia ion running 4.0.4 not giving video call
what should be the reason..............
Solved! Go to Solution.
it should work just fine, uninstall it and re-install it, remember that you need a data plan/wifi
UNRELATED topic, if you have some time please check this thread
have u check the settings on your skype app? maybe u disable video calling. im using skype everyday and i can use video calling without any issues.
