WiFi is not working after updating to ICS
SOLVED
arunkrishna
Visitor
Hi!!!
       I'am from india . 2 weeks back I'hv got new xperia U, today i got ICS update,,,Finally!!!! But after updating ,WiFi is not working in my phone. Whenever i tried to turn on ,it keep on displaying "Turning on Wi-Fi".... but nothing works after it!!!:smileyconfused:
Plz help me out..... asap:smileysad:
Thank u
11 REPLIES 11
dragpyre
Contributor
Arnab wrote:
upgrading via PCC is as simple as connecting the phone to PC via USB. A better way to upgrade is using Sony Update Service (SUS).
There are some bugs in ICS, but they are mostly solved by a settings reset or worst come worst a repair.
Charge is used faster, there seems to be some notification sound problems and some wifi issues. I am not personally facing any issue but these are the common ones in the forum.
I've found improved battery life in ICS, my notifications for email, texts, whatever come through fine, and Wi-Fi issues can be solved sometimes by specifying an IP address manually for WPA(2)/PSK networks, then enabling DHCP.
This is a common fault in most Android builds, including Jelly Bean on the Nexus 7.
ameya_des1
Visitor
Mine does even after upgrading to ics. Do you know any solution?
