Hi all!
First of i would like to say that i did all the research that i possibly could and I am by no chance pc or mobile wiz so please be patient with me.
I know you have 10000s of questions like this but please try to help me.
I have sony xperia S with all the latest updates(i bought the phone few days back and it updated by default) and i belive i have android version 4.0.4.
My problem is as many users here have is that i cannot connect my mobile to PC. I tried most of the solutions and nothing worked , all of the solutions i saw include deleting mtpapp which I DONT HAVE!
I have win xp .
it says i have LT26i and version 6.1.A.2.45
Please help me i am going nuts here
Solved! Go to Solution.
install SUS > restart your PC > disable your antivirus and firewall > run SUS > turn off your Xperia S > press and hold the volume down button > connect your phone to your PC > your PC should start downloading the drivers, do NOT release the button
UNRELATED topic, if you have some time please check this thread
jesus its finally going somewhere...its installing a file, 371MB , is that ok
yes that's fine
for future reference
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
i downloaded SUS today and funny thing is i tried this but i did not turn the phone off(in croatian tutorial they said to unplug it- go figure).
version that i hae(SUS) is 2.12.15.18. is there a newer version or is this the latest?
that should be the latest
thanks man if this works, drinks are on me
been messing with this 2 days now ,hope it works
it should work
its still the same- i get that pop up baloon saying: found new hardware: MTP DEVICE and it goes on and on and on...
go to my computer > xperia s > internal storage
