Hi all!
First of i would like to say that i did all the research that i possibly could and I am by no chance pc or mobile wiz so please be patient with me.
I know you have 10000s of questions like this but please try to help me.
I have sony xperia S with all the latest updates(i bought the phone few days back and it updated by default) and i belive i have android version 4.0.4.
My problem is as many users here have is that i cannot connect my mobile to PC. I tried most of the solutions and nothing worked , all of the solutions i saw include deleting mtpapp which I DONT HAVE!
I have win xp .
it says i have LT26i and version 6.1.A.2.45
Please help me i am going nuts here
Solved! Go to Solution.
i dont have it... the xperia S
interesting, do you have another PC to test?
phone says that internal memory is turned ON and also when i go to device manager i see Sony sa0103,
Device type: Sony sa0103
Location 0(LT26i)
no,sorry...
i also want to say that only if i turn that usb debug thing only then it shows internal memory on the phone as turned on
do you have another PC w/ win7?
no i am sorry, but let me tell you also, when i open device manager in i have something called portable device and inside is icon MTP DEVICE with yellow exclamation on it and says code 10.
- when I plug the phone in usb(this is without usb debugg) just for a second i see "found new hardware LT26i" and then after than comes that annoying MTP msg all the time.
well it seems its my pc. tested it on win 7 laptop and it worked like a charm. installed everything in a matter of secs... well at least i know its not my phone, now i must change my windows.
thanks again for all the help
anytime
UNRELATED topic, if you have some time please check this thread
