- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
xperia z gyroscope problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Dr. Yamen.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My Gyroscope was working well last week and now it isn't, what I just did is i turned it off for a few minutes and put it in clean water (since last week I was at the beach and it got some salty water on it) anyway when I turned it on and did the Test again it worked! probably it's just turning the phone off for a few minutes fixed the issue, try it good luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, I have done a soft reset hard reset and nothing seems to work, the problem still persists, even tried disabling apps that i have downloaded and upgraded but the problems still persists. I have now decided to send my device in for repairs and have to wait three weeks for my device. Does anyone know what else could cuase this problem or how to prevent it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hello
i was wondering if you were able to solve your problem ? beacuause i have the same issue and its killing me
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks you for your reply yea i guess i wiill have to send mine in too how long did it take them to send it back ? and why did u have to send it in twice ?
thanks alot for the help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thank you very much for taking the time to respond i will probably be sending mine in Thanks again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there. The problem occured to me a couple of days ago on Z1, I restarted my phone and it works now. I'll update if problem returns but I suggest anyone who encounters the problem tries that first.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
wow still now official answer on this pressing matter? my xperia Z1 is also has this issue for the longest. my phone was fine before i updated to android 5.0 LP. the issue never existed on kitkat. rebooting the phone is the only temporary fix for the issue (for about 30 min-2 hr), then after regular use the issue would return. then it happens all sensors go down.
gyroscope down
compass down
light sensor down
proximity sensor down
downgrading back to KK makes the issue take longer to affect but is still there.
leaves me to think its a Firmware kernel issue.
