Z3 compact back and home button not working after recent update
SOLVED
Haystax
Visitor
My back and home button not working now after. 5. 1.1 update.
158 REPLIES 158
Diego47
Visitor
The problem is software, bacause the game clash royale uses that zone (back and home) and works correctly.
fckw
Visitor
There are many people with this issue and apparently no solution at the horizon.
So, the issue is known since 2015, and still Sony has not provided any solution. To me it looks like there is a delibate ignoring of this issue. It's a shame because otherwise this is a great phone with the longest battery duration I've ever seen for a smart phone (with flight mode on during night battery lasts 1 week for me). So, then it'll probably be either Samsung or Apple for me in the future.
bs9
Visitor
The same problem with Sony Xperia z3
Leafy1
Visitor
Got my Xperia XZ 6 weeks ago, and now the home button and back button and the other one (can't remember what it is called) not working at all.
princesssueie
Visitor
WHY DOES THE SECOND POSTER IN THIS THREAD SAYS ITS THE SCREEN AND ITS MARKED AS SOLVED BY SONY?
THIS IS NOT THE REASON IN ANY WAY AT ALL!!!
PROVE: Screen in those areas work perfect for ALL in games using that area.
SOOOOOOOO.......
WHY DOES IT SAY SOLVED?
(sherlock mode on)
POSSIBILTES LEFT ARE
  1. SONY COVERING UP THEIR BAD SOFTWARE UPDATES WHICH IS CAUSING THIS PRODUCT BREAKING FAULT
  2. THE MUSLIMS/TRUMP/N.KOREAN/FRENCH DID IT...
...I THINK A CLASS ACTION COMING ON,, ANY LAWYERS AROUND?
Guilhermelimpo
Visitor
Sony, never again!
Uliwooly
@Leafy
Wrong thread, contact your Local support to get it inspected.
Uliwooly
@princesssueie
Have you contacted your Local support to get your device inspected ?
sverza
Visitor
@princesssueie, in my opinion the class action could be a good idea but... for what I know the class action is for the single nation/state.
Then in every single state the class action should collect more and more users.
There should be someone/some authority that starts the class action.
Unfortunately I don't think this could be easily done
kilargo
Visitor
I have the the same issue, after marshmallow 6.0.1 update the following is no-longer working:
On basic diagram numbers:
2. Recent apps
3. Home key
4: Back key
tried reset, repair, now fully back to factory setting without success. Did back up but then when tried to transfer back to phone, it didn't work so now have lost all contacts. What's going on!!
