i think i have same problem
try to put WI-FI off then make your call
I have the same issue!
After several factory resets and replacement of the ear speaker, still same thing, even in safe mode. Anybody found a solution? I can't even tell if this is a software or hardware issue...
Cheers
I have the same issue. My Z5 Compact is less than one year old. Some weeks back the ear speaker has stopped working, often a couple of seconds after answering. I have tried the safe mode, the problem was the same. Diagnostics show that the hardware works fine. Just now I really cannot phone or answer calls, they all end up me telling that I cannot hear the other person. I have Android 6.0.1, updated as soon as it came available. Model number E5823. I have still not experimented with wifi.
Same problem with de Z5 Compact I bought 1 month ago... The speaker has been replaced and it still not working at all. Software updated also but no luck either. Any ideas?
I'm really dissapointed with Sony... this kind of things shouldn't happen!
Please, someone help!
