Hi all,
I got the new Anfdroid Gingerbread upgrade last night, but have only just found out that the the back up I ran using the the SE app will not be accessible after running the upgrade!!
Can anyone please let me know if any of the apps on android market can pick up my backup and restore it to my X10, as I've basically now got a phone with no contacts, apps, messages or any data what so ever on it!!! HEEEEELLLLPPP!!!
Cheers
Odub
Solved! Go to Solution.
Hi I have downloaded the io file manager onto the phone but where do I get the backup and restore app from to install and who made it, sorry for being thick here,
Uliwooly to the rescue
if you need the app you can use this link instead to download the apk
New Link
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Click on Backup & Restore to download the app
i could use some help too =P well i got the backup and restore app to install. but when i click restore and then click on my file, the app crashes again. anyone have any input on how i can fix this?
I had the same problem as your other guys, on my X10 Xperia, no problem in DL the OL or Backup & Restore, but they all said "program not installed" after trying to install the app, exept davidferro´s link:
http://www.mediafire.com/?78bcyp5alpwy0ok it installed without any problems, and is currently restoring data...... i DL the apk to my computer and moved it to the SD and the opened it and istalled it....
just waiting for it to complete the restore so far there is no problems.....onlys SMS is left..... and it´s done and it works!! GOOD THREAD!!!! ;-D
http://www.mediafire.com/?78bcyp5alpwy0ok This is a really easy fix, thank you all very much for the help and all the great work done on our behalf.
I just downloaded the file straight on to the phone and opend the app and did a restore and hey presto, I am such a happy chappie now.
You are SO clever - thank you!
I was crying like a little girl earlier, and now I'm all happy again.
You are my hero!!! :o))
hahaha I'm glad I was of some help
Uliwooly - I find people like you who sort out luddites like me great. I guess you do this without any pay - I hope Sony Ericsonn appreciate that you have helped a lot of people get back the restore file that they had done in good faith to get back their contacts. Most of us thought that by doing the back up that even with the warnings by Sony during the Gingerbread update that we would at least still have our contacts. Yes I had a paper/PC folder back up but wanted it back on my phone in an easy manner and not a key in 300+ contact phone, mobile and email details.
Thank you for the time you spend and I hope that Sony Ericson learn something too. I would like to see their tablet do well as I have enjoyed the Xperia 10 (and it wasn't my choice of phone). The Xperia 10 has so far exceeded my expetations and the help you and Davieforro gave was tremendous. Cheers lir.
I'm glad I could help
