Xperia Ion 3G speed issue
SOLVED
bintop
Visitor
Hi
I am from chennai(India)
4 days before i bought xperia ion.
Problem is 3G slow speed
My Airtel 3g speed in xperia ion is max 60kb ...!(Screen shot attached)
but Signal reception & voice call is very well,
getting full 3G signal.
Also 2g net working fine.
and I Checked with another service provider Aircel 3G and it is working very well (Speed getting 7 mb/s)
Anybody facing the same issue?Kindly help me...
(Airtel CC don't know the reason Slightly_frowning_Face  )
My oldxperia  neo v 3g wrking fine with my airtel sim...!
Is it phone problem ?
1 ACCEPTED SOLUTION
Accepted Solutions
bintop
Visitor
Finally the problem solved with new firmwire updation(6.1.E.2.68).Thanks sony for the solution.
25 REPLIES 25
Sam
Legend
Legend
Unfortunately this is almost certainly a network issue, however it would be worth trying a secondary SIM.
What are your thoughts about this forum? Let us know by doing this short survey.
bintop
Visitor
Well but my xperia neo v phone getting full 3G speed with the same airtel  card...!
karthiknss
Visitor
Even My xeperia ion has the same issue.  2g works better. But using 3g @ rest of tamilNadu works nfine except in chennai.
And 3g works pretty good in my old mobile nokia e72.
After registering complaintt in customercare both chennai and rest of tamil nadu failed to work.
bintop
Visitor
So is this phone problem or network problm:smileyshocked:
karthiknss
Visitor
hopefully network, im about to try number portability. If the other network too doesnt worked means then i wont recommend this phone at all.
karthiknss
Visitor
only waste of money Thinking_Face
bintop
Visitor
I love Ion solid build & design other wise definitely  I will choose Galaxy S3. Price is same only.
But now i am totally fedup ..!
My Airtel connection is  in CUG plan.No I can't do MNP Slightly_frowning_Face
bintop
Visitor
saravanakumar
Visitor
I am facing the same problem, can any one help me regarding this how to update the new firmwire updation(6.1.E.68), myself indian user....
