Xperia Ion 3G speed issue
SOLVED
bintop
Visitor
Hi
I am from chennai(India)
4 days before i bought xperia ion.
Problem is 3G slow speed
My Airtel 3g speed in xperia ion is max 60kb ...!(Screen shot attached)
but Signal reception & voice call is very well,
getting full 3G signal.
Also 2g net working fine.
and I Checked with another service provider Aircel 3G and it is working very well (Speed getting 7 mb/s)
Anybody facing the same issue?Kindly help me...
(Airtel CC don't know the reason Slightly_frowning_Face  )
My oldxperia  neo v 3g wrking fine with my airtel sim...!
Is it phone problem ?
25 REPLIES 25
bintop
Visitor
Download , install & run sony pc companion :-  http://www.sonymobile.com/in/tools/pc-companion/
Connect your phone to PC then follow the instructions.
Software update duration15 min with 4mb brodband connection.
Uliwooly
SUS it's a lot faster than PCC
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
karthiknss
Visitor
Cool... It worked...  Thanks Sony.. But my phone gets heated rapidly also battery drains completely  in 1 hr if I enabled data service. Is this a new bug or my device issue?
bintop
Visitor
I have no issues.Just do phone reset.
karthiknss
Visitor
Factory reset?
bintop
Visitor
yes..
karthiknss
Visitor
Omg... Ok :smileycry:.
saravanakumar
Visitor
i have tried with PCC and SUS, but it show us you already have the latest update in your phone. i am having XPERIA ION (LT28h) and its build number(6.1.E.1.20). i want to fix the 3G problem, it occuring for AIRTEL network.. 3G is working fine for Aircel. i could not find any update in the build number (6.1.E.1.68). Please anybody help me regarding this issue.
saravanakumar
Visitor
I can not find the solution for this problem, please help me regarding this firmware(6.1.E.2.68) update.i tried to connect through PCC and SUS but i can see only firmware update (6.1.E.2.23) for my mobile sony xperia LT28h. I am in position to change the network to aircel, if it is not resolved. can you please confirm me where you got this (6.1.E.2.68) update or any contact person ?
bintop
Visitor
From where you bought the phone?If it is indian version,definitely you will get the updation.
This firmware only for specified countires.
