Hello,
I've a problem with my new XperiaS, the wifi connection automatically switch on without reason and I can't find a way to stay off.
What can i do to make sure that does not turn on without my command?
Thanks and sorry for my english.
Solved! Go to Solution.
Thanks for the help, the problem seems to be Go Battery Saver, because now the wifi try already to switch ON alone sometimes, but it switch off before he turns totally ON.
See
would you still like to say this
I will try, but it doesn't make sense imho, there should be some Xperia bug if an app that works on two other phone (Nexus S and GS2) without problem, doesn't work on Xperia S.
Enjoy your phone :smileycool::smileygrin::smileywink:
Yes a bug there still is, because the phone tries to turning ON wifi, and it IS a bug, but without this app it doesn't reach tu turning ON and the wifi indicator appears grey and do not became white (turning ON definitly).
So imho there is a bug, but you've gave my a reasonable solution.
Okh okh :smileygrin: :smileygrin:
Please pay attention to these problems:
http://talk.sonymobile.com/thread/55321
http://talk.sonymobile.com/message/350786#350786
http://talk.sonymobile.com/message/350738#350738
http://talk.sonymobile.com/message/223550#223550
(there may be more posts)
They all refer to the same issue!! Still with NO solution. And is being given little attention by SONY!
<<< Wi-fi won't turn off and stops working even though it's "on" >>>
