Xperia tx produce more heat
SOLVED
Naveenkannan27
Visitor
My Xperia tx produces more heat on screen and back of the phone while using wi fi or data traffic. Are others facing the same problem? Is there something I can do.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
that's not an issue it's normal on smartphones.
5 REPLIES 5
Uliwooly
Naveenkannan27
Visitor
Hope that's true. I afraid if this has any impact on hardware performance and life
Daloch
Contributor
My T do not produce much heat while using wifi.  Just a little.
It is much much worse when gaming,  but it's normal.
Uliwooly
if it gets too hot, your phone will shut down by itself
Daloch
Contributor
At least the phone will not burn!!
:smileywink::smileywink:
