My Xperia tx produces more heat on screen and back of the phone while using wi fi or data traffic. Are others facing the same problem? Is there something I can do.
Solved! Go to Solution.
Hope that's true. I afraid if this has any impact on hardware performance and life
My T do not produce much heat while using wifi. Just a little.
It is much much worse when gaming, but it's normal.
if it gets too hot, your phone will shut down by itself
At least the phone will not burn!!
:smileywink::smileywink:
