Notification bar displaying by itself
CharlotteK
Visitor
Hi, can you please help me? My Z3 Compact has just started displaying the notification bar by itself, I am trying to use my phone, type messages etc and it just keeps coming down which is making the phone unusable. I've  tried re starting it, soft reset and safe mode, it just keeps doing it! Can anyone help please?
Tags (1)
27 REPLIES 27
sibhaca
Visitor
I also encountered this issue a while ago, now it becomes no respond when I drop it. Nitrification bar now can't work at all.
jhent0815
Visitor
I´ve got the same problem. It started 2 days ago. The notification bar and sometimes even the menu (that normally just comes up if you touch the notification bar again) will randomly pub up while useing the touchscreen.
Touchscreen test in diagnostics works fine and no pop ups there. While typing the problem seems to be much worse than while just browsing through screens.
Firmware 23.4.A.1.264
P.S.: Before that problem occured i had trouble for 2-3 days to open up the notification bar at all. Sometimes it would just work after switching the screen off and on again.
P.P.S.: I just tried to repair the firmware with PC Companion. This didn´t solve the problem.
JW2
Visitor
I'm having the same issue since two days. Did anyone ever receive report for this? It seems like it's affecting a few people.
prem_kkp
Visitor
I'm also experiencing the same problem. Any solution?
CharlotteK
Visitor
Hi nope sorry not that I found, I ended up getting a new phone, was really annoying.
Gav89
Visitor
Hello, I'm wondering if anyone may also be experiencing this issue and/or know how to resolve it.
When I'm typing on my Xperia Z3 Compact, or scrolling through pages, the status/notification bar often pulls itself down, so it interrupts me when I'm typing and as you can imagine it's quite frustrating!
Would anyone have any suggestions on what to do to try and eradicate the problem?
Thanks,
Gavin
SlightlyMiffed
Visitor
I now have this problem, any fixes?
SlightlyMiffed
Visitor
I seem to have a patch on the screen, in the middle that seems to affect the notification bar. If I go to an empty home screen I can press a certain part of the screen and initiate the notification bar coming down. I presume somehow that the sensor is damaged and it thinks that when I press the point on the middle of the screen it thinks it's the top of the screen. I think.
Fez
Visitor
Hi,
My phone started doing this, this morning. No signs of screen damage it has a screen protector on it. Was working fine last night just put it to charge this morning and now the notification bar wont stop dropping down.
Has anyone managed to fix this? Only had the phone around 3 months so would really rather repair then have to buy a new one....
Thanks Slightly_smiling_Face
boomaker
Visitor
Exactly same problem since this morning... Really annoying!!
How all of you fixed the issue?
Thanks!
