Rooting Xperia S with offical ICS with unlocked bootloader
SOLVED
zipo13
Visitor
Hi,
I want to root my Xperia S to use Titanium Backup.
I upgraded it to ICS 4.0.4 a week ago using sony update tool.
I have unlocked the bootloaded by sony offcial method.
It wiped my phone clean (I didn't expect that but luckly I had backup of most of the stuff)
Now I saw some instructions on rooting the Xperia S but all of them say that it will wipe the phone clean again.
Example:
http://www.android.gs/root-sony-xperia-s-official-ics-6-1-a-0-452-rom/
Is there a way to root the device now that the boot loader is unlocked without wiping it?
18 REPLIES 18
Uliwooly
yes you do
Uliwooly
this is how
click on rooting
http://talk.sonymobile.com/thread/41609
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
delwoods
Visitor
Seeing as you have an unlocked bootloader why not flash a custom kernel which is already pre rooted ?
kartik77
Visitor
We can also have rooting on locked bootloader. I could find 2 methods . One is short and other is long.http://www.androidust.com/root-xperia-s-with-locked-bootloader-new-method/
ksharawat
Visitor
dude its showing
Not Found
Error 404
Thommo
2 and a half months ago I posted that link for my drive but if you need it here it is
https://docs.google.com/open?id=0B-yM_qnM8ZPRX0loZWgxMGFKNmc
ksharawat
Visitor
thanx dude
manu34400
Visitor
it does work... it says NOT FOUND Error 404... can you give me the new link please??? i'm in a big trouble if a don't find a system.img for ICS. :s
Thommo
A system image is different from a rooted image if it's a system image you need then you'll be after a FTF file for use with flashtool - Here's the UK .453 ICS ftf file https://docs.google.com/open?id=0B-yM_qnM8ZPRRy1xV1A5X2xYXzA
