Synchronization problem with Google & SE
SOLVED
Not applicable
After the last update ( software n : 2.1.A.0.435) my phone doesn't make contacts sync nor with Google account neither with SE, when I try to make it manually everything looks OK but when I open my accounts on PC there is no Change!!!
Before the last update it was working perfectly, I tried many times and no changes.
Did any one face this problem??
35 REPLIES 35
suze
Leader
How about using this programme http://www.fjsoft.at/en/highlight.php to copy your contacts from your phone to your PC then to your gmail account, then repair your phones software with Sony Ericsson Update Service and start it all from scratch to see if that resolves the issue. This will obviously wipe your phone back to factory settings. Do not import your contacts from SIM or SD just select the Google Sync in the Phone book via the three headed figure.
Not applicable
Good idea, thank you
Not applicable
my backup root will also back up all your contacts, bookmarks, call log, sms, mms, system settings, android home settings, , etc, etc...directly to your sd card...then you can leave it there in case you need it again and overwrite it the next time you need to update.
THat's my personal choice when I need to back up all that stuff.  It also is the only app I've found that will back up angry birds gamesaves....that's a very big one in my book lmao
Uliwooly
you should re-install (re-flash) 2.1 that might solve it.
Uliwooly
suze sorry I didn't realized you already suggested myphone explorer. Dizzy_Face
soph246811
Visitor
i had that problem and i had to do a factory reset and it got rid of the problem x
